0000271QElectroTechDiagram Editorpublic2026-09-22 11:31
Reporterkas1kas Assigned To
PriorityhighSeveritytextReproducibilityalways
Summary0000271: Font size incorrect when using Chromebook
DescriptionText is not the same size when opening an existing drawing made on windows. This cuases it not to fit in the space. Overlapping is the result and so lot of text is unreadable.
Steps To Reproducecreate project in Windows, open in Chromebook.
Additional InformationThis happens in v0.8 and 0.9
TagsNo tags attached.
Activities
scorpio810_mantis
2022-09-06 07:40
administrator   ~0000574
Thanks, but we don't have a chromebook setup to try.
You use Crouton?
The fonts is the same on Windows and chromebook?
Maybe try to install Microsoft TrueType Fonts:
https://itsfoss.com/install-microsoft-fonts-ubuntu/
kas1kas
2022-09-06 20:27
reporter   ~0000575
I will try to install the fonts to see if that helps.
Maybe I can find a font that is shared between Debian and Windows. I'll follow up.
The linux on Chromebook is
~$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
scorpio810_mantis
2022-09-07 05:13
administrator   ~0000576
Btw, you have my Debian repo for 0.9-dev for Bullseye
https://qelectrotech.org/wiki_new/doc/install_debian
scorpio810_mantis
2022-09-07 05:17
administrator   ~0000577
https://qelectrotech.org/forum/viewtopic.php?id=1420
kas1kas
2022-09-07 10:23
reporter   ~0000578
Unfortunately https://qelectrotech.org/forum/viewtopic.php?id=1420 is all in French.
kas1kas
2022-09-07 10:28
reporter   ~0000579
"Btw, you have my Debian repo for 0.9-dev for Bullseye
https://qelectrotech.org/wiki_new/doc/install_debian"
I used the QElectroTech_0.9-DEV-r7679-x86_64.AppImage on my Chromebook.
scorpio810_mantis
2022-09-07 10:48
administrator   ~0000580
https://qelectrotech-org.translate.goog/forum/viewtopic.php?id=1420&_x_tr_sl=fr&_x_tr_tl=en&_x_tr_hl=fr&_x_tr_pto=wapp
Issue History
2022-09-05 16:43 kas1kas New Issue
2022-09-05 16:43 kas1kas File Added: Screenshot 2022-09-05 16.37.46.png
2022-09-06 07:40 scorpio810_mantis Note Added: 0000574
2022-09-06 07:40 scorpio810_mantis Note Edited: 0000574
2022-09-06 07:44 scorpio810_mantis Note Edited: 0000574
2022-09-06 20:27 kas1kas Note Added: 0000575
2022-09-06 20:30 kas1kas Note Edited: 0000575
2022-09-07 05:13 scorpio810_mantis Note Added: 0000576
2022-09-07 05:17 scorpio810_mantis Note Added: 0000577
2022-09-07 10:23 kas1kas Note Added: 0000578
2022-09-07 10:28 kas1kas Note Added: 0000579
2022-09-07 10:48 scorpio810_mantis Note Added: 0000580
2026-09-22 11:31 scorpio810_mantis Status new => resolved
2026-09-22 11:31 scorpio810_mantis Resolution open => fixed
