0000255QElectroTechDiagram Editorpublic2026-09-24 11:25
Reportermjulius Assigned To
Status newResolutionopen
Summary0000255: UI text scaling on high DPI screen incorrect
DescriptionI use QET on a high DPI screen under Windows 10. The scaling for Text and apps on that screen is set to 200%.
In QET the icons and some text elements of the UI are scaled correctly while some other texts are not. See screenshot attached. There for example The main menu and the list on the left are correct and the labels on the tabs are too small.
TagsNo tags attached.
QET UI.png (37,970 bytes)
Activities
scorpio810_mantis
2022-02-08 16:31
administrator   ~0000539
Have you tried HDPI options?
mjulius
2022-02-11 13:26
reporter   ~0000540
These settings do not seem to have any effect on the texts in UI widgets. I am not sure what they actually are supposed to do. Is this about the display in the drawing area?
Correctly scaled are the main menu, the title bars on the panels and the tree views on the panels. Not scaled are the labels on tabs, toolbars and buttons, and the texts in input boxes, drop down boxes and so on. Icons and controls like check boxes are scaled correctly while their labels are not.
Interestingly, when I start QET on a normal resolution screen and then move it to a high DPI screen all texts are scaled correctly, but, icons are not.
And then, when I start QET on the high DPI screen set to 100 % scaling, and change the scaling factor to 200 % afterwards, everything seems to be as it should be. So this could be a workaround.
scorpio810_mantis
2022-03-04 07:44
administrator   ~0000543
Thanks for feed back.
ispyisail
2026-09-24 11:25
developer   ~0000885
Could you try a current development build? The Windows development builds now use Qt 6, which handles high-DPI scaling differently from the Qt 5 versions this was reported on. Please add a note saying whether the tab, toolbar and button labels still stay small at 200 %.
Issue History
2022-02-08 13:06 mjulius New Issue
2022-02-08 13:06 mjulius File Added: QET UI.png
2022-02-08 16:31 scorpio810_mantis Note Added: 0000539
2022-02-08 16:31 scorpio810_mantis File Added: HDPi_settings.png
2022-02-11 13:26 mjulius Note Added: 0000540
2022-03-04 07:44 scorpio810_mantis Note Added: 0000543
2026-09-24 11:25 ispyisail Note Added: 0000885
