0000244QElectroTechDiagram Editorpublic2022-04-01 20:08
Reporterplc-user Assigned Toblack_sun
PriorityhighSeveritycrashReproducibilityalways
Status resolvedResolutionreopened
Platformx86_64OSwin10 and debian unstableOS Versionsee description
Summary0000244: segmentation fault when closing project
DescriptionIf a resource directory (German: "Betriebsmittelverzeichnis", Menu-Text: "nomenclature") is inserted into a project that is longer than one page, QET will reproducibly crash when the project or the program is closed.
In the appendix you will find an example project in which QET crashes reproducibly.
On Win10 No entry appears in the log file.
Linux says: "segmentation fault"
QET "ReadyToUse" - Version on win10:
QElectroTech V 0.90-DEV+a765fe24bc957a06d79751d3
Compilation : GCC 9.3.0
Built with Qt 5.15.2 - Date : Sep 8 2021 : 08:08:42
Run with Qt 5.15.2 using 12 thread(s)
CPU : NAME INTEL(R) CORE(TM) I7-8700 CPU @ 3.20GHZ
RAM Total : 32547 MB
RAM Available : 24801 MB
GPU : VideoProcessor Intel(R) UHD Graphics Family
GPU RAM : RAM Total : AdapterRAM 1073741824 B
OS : winnt - x86_64 - Version : Windows 10 Version 1909 - Kernel : 10.0.18363
*** Qt screens ***
( 1 : 1920 x 1200 )
( 2 : 1920 x 1200 )
Linux / Debian - Version of QET:
QElectroTech V 0.90-DEV+ccfb46b35c957a06d79751d3
Compilation : GCC 10.3.0
Built with Qt 5.15.2 - Date : Sep 14 2021 : 08:03:01
Run with Qt 5.15.2 using 8 thread(s)
CPU : model name : Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz
RAM Total : 15894 MB
RAM Available : 14521 MB
GPU : Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] (rev 02)
GPU RAM : @ToDo
OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.10.0-8-amd64
*** Qt screens ***
( 1 : 1920 x 1080 )
Steps To Reproduce- create project with "enough" elements (25 in attached example)
- insert / add nomenclature (Betriebsmittelverzeichnis)
(- save project)
- close project (ctrl+w)
TagsNo tags attached.
QET-Crash-Test.qet (63,202 bytes)
<project version="0.90" title="QET-Crash-Test">
    <titleblocktemplates>
        <titleblocktemplate name="für A3">
            <information/>
            <logos/>
            <grid rows="20;20;20;20;" cols="t15%;t10%;r100%;t10%;t15%;">
                <field name="creator" hadjust="true" displaylabel="true" align="left" col="0" row="0" valign="center">
                    <value>
                        <translation lang="en">%creator</translation>
                    </value>
                    <label>
                        <translation lang="fr">Createur</translation>
                        <translation lang="en">Created</translation>
                        <translation lang="de">Urspr.</translation>
                    </label>
                </field>
                <field name="title" fontsize="16" hadjust="true" displaylabel="false" align="center" col="2" row="0" valign="center" rowspan="3">
                    <value>
                        <translation lang="en">%title</translation>
                    </value>
                    <label>
                        <translation lang="fr">Titre</translation>
                        <translation lang="en">Title</translation>
                        <translation lang="de">Titel</translation>
                    </label>
                </field>
                <field name="anlage" fontsize="9" hadjust="true" displaylabel="true" align="left" col="3" row="0" valign="center">
                    <value>
                        <translation lang="de">%plant</translation>
                    </value>
                    <label>
                        <translation lang="de">Anlage</translation>
                    </label>
                </field>
                <field name="filename" fontsize="9" hadjust="true" displaylabel="true" align="left" col="4" row="0" valign="center">
                    <value>
                        <translation lang="de">%filename</translation>
                    </value>
                    <label>
                        <translation lang="de">Datei</translation>
                    </label>
                </field>
                <field name="date" hadjust="true" displaylabel="true" align="left" col="0" row="1" valign="center">
                    <value>
                        <translation lang="en">%datecreated</translation>
                    </value>
                    <label>
                        <translation lang="fr">Date</translation>
                        <translation lang="en">created</translation>
                        <translation lang="de">erstellt</translation>
                    </label>
                </field>
                <field name="ort" fontsize="9" hadjust="true" displaylabel="true" align="left" col="3" row="1" valign="center">
                    <value>
                        <translation lang="de">%locmach</translation>
                    </value>
                    <label>
                        <translation lang="de">Ort</translation>
                    </label>
                </field>
                <field name="" fontsize="9" hadjust="true" displaylabel="true" align="center" col="4" row="1" valign="center">
                    <value/>
                    <label/>
                </field>
                <field name="author" hadjust="true" displaylabel="true" align="left" col="0" row="2" valign="center">
                    <value>
                        <translation lang="en">%author</translation>
                    </value>
                    <label>
                        <translation lang="fr">Auteur</translation>
                        <translation lang="en">last Author</translation>
                        <translation lang="de">Bearb.</translation>
                    </label>
                </field>
                <field name="" fontsize="9" hadjust="true" displaylabel="true" align="center" col="3" row="2" valign="center">
                    <value/>
                    <label/>
                </field>
                <field name="revision" fontsize="9" hadjust="true" displaylabel="true" align="left" col="4" row="2" valign="center">
                    <value>
                        <translation lang="de">%indexrev</translation>
                    </value>
                    <label>
                        <translation lang="de">Rev.</translation>
                    </label>
                </field>
                <field name="date" hadjust="true" displaylabel="true" align="left" col="0" row="3" valign="center">
                    <value>
                        <translation lang="en">%date</translation>
                    </value>
                    <label>
                        <translation lang="en">Date</translation>
                        <translation lang="de">Datum</translation>
                    </label>
                </field>
                <field name="" fontsize="9" hadjust="true" displaylabel="true" align="center" col="3" row="3" valign="center">
                    <value/>
                    <label/>
                </field>
                <field name="folio" fontsize="9" hadjust="true" displaylabel="true" align="left" col="4" row="3" valign="center">
                    <value>
                        <translation lang="de">%folio</translation>
                    </value>
                    <label>
                        <translation lang="de">Seite</translation>
                    </label>
                </field>
            </grid>
        </titleblocktemplate>
    </titleblocktemplates>
    <properties>
        <property name="saveddate-eu" show="1">16-09-2021</property>
        <property name="saveddate" show="1">16.09.21</property>
        <property name="savedtime" show="1">19:56</property>
        <property name="saveddate-us" show="1">2021-09-16</property>
        <property name="savedfilepath" show="1">/home/ich/Schreibtisch/QET-Crash-Test.qet</property>
        <property name="savedfilename" show="1">QET-Crash-Test</property>
    </properties>
    <newdiagrams>
        <border rows="8" cols="15" rowsize="80" colsize="72" displayrows="true" displaycols="true"/>
        <inset filename="" date="null" auto_page_num="Neue auto-nummerierte Folie anlegen" titleblocktemplate="für A3" plant="" author="" version="" folio="%id/%total" displayAt="bottom" indexrev="" title="" titleblocktemplateCollection="custom" locmach="">
            <properties>
                <property name="date" show="1"></property>
                <property name="filename" show="1"></property>
                <property name="plant" show="1"></property>
                <property name="author" show="1"></property>
                <property name="folio" show="1"></property>
                <property name="creator" show="1"></property>
                <property name="indexrev" show="1"></property>
                <property name="datecreated" show="1"></property>
                <property name="title" show="1"></property>
                <property name="locmach" show="1"></property>
            </properties>
        </inset>
        <conductors conductor_section="" num="_" dash-size="2" vertical-alignment="AlignRight" type="multi" tension_protocol="" cable="" conductor_color="" formula="" horizrotatetext="0" color2="#000000" vertirotatetext="270" condsize="1" text_color="#000000" onetextperfolio="1" displaytext="1" bus="" horizontal-alignment="AlignBottom" function="" numsize="7" bicolor="false"/>
        <report label="%f-%l%c"/>
        <xrefs>
            <xref xrefpos="" powerprefix="" master_label="%f-%l%c" offset="0" slave_label="(%f-%l%c)" switchprefix="" delayprefix="" snapto="label" showpowerctc="false" displayhas="cross" type="protection"/>
            <xref xrefpos="AlignTop" powerprefix="" master_label="%f-%l%c" offset="40" slave_label="(%f-%l%c)" switchprefix="" delayprefix="" snapto="label" showpowerctc="false" displayhas="cross" type="coil"/>
            <xref xrefpos="" powerprefix="" master_label="%f-%l%c" offset="0" slave_label="(%f-%l%c)" switchprefix="" delayprefix="" snapto="label" showpowerctc="false" displayhas="cross" type="commutator"/>
        </xrefs>
        <conductors_autonums current_autonum="" freeze_new_conductors="false"/>
        <folio_autonums/>
        <element_autonums freeze_new_elements="false" current_autonum=""/>
    </newdiagrams>
    <diagram version="0.90-DEV+ccfb46b35c957a06d79751d3" rowsize="80" cols="15" folio="%id/%total" order="1" plant="" title="" locmach="" author="" displayrows="true" date="null" freezeNewElement="false" displayAt="bottom" colsize="72" displaycols="true" auto_page_num="" indexrev="" freezeNewConductor="false" height="660" rows="8" filename="" titleblocktemplate="für A3" titleblocktemplateCollection="embedded">
        <properties>
        </properties>
        <defaultconductor conductor_section="" num="_" dash-size="2" vertical-alignment="AlignRight" type="multi" tension_protocol="" cable="" conductor_color="" formula="" horizrotatetext="0" vertirotatetext="270" color2="#000000" condsize="1" text_color="#000000" onetextperfolio="1" displaytext="1" bus="" horizontal-alignment="AlignBottom" function="" numsize="7" bicolor="false"/>
        <elements>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{d293e3ed-deaa-4b37-becb-ffe7746df548}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="270">
                <terminals>
                    <terminal orientation="0" y="-6" id="0" x="0"/>
                    <terminal orientation="2" y="6" id="1" x="0"/>
                </terminals>
                <inputs/>
                <elementInformations>
                    <elementInformation name="formula" show="1"></elementInformation>
                    <elementInformation name="comment" show="1"></elementInformation>
                    <elementInformation name="label" show="1"></elementInformation>
                    <elementInformation name="location" show="1"></elementInformation>
                </elementInformations>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{175d3a39-a5e9-4415-b86c-ea43b2ac4f05}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    </dynamic_elmt_text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{a428ee99-1405-417c-a920-70d9f96c22e7}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                        <info_name>label</info_name>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{aca2f4aa-75ee-405d-bea7-6ac8bbe44af3}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="210">
                <terminals>
                    <terminal orientation="0" y="-6" id="2" x="0"/>
                    <terminal orientation="2" y="6" id="3" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{f538140b-a103-406e-8045-66d258bba9f9}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{6455d4c1-880e-4a0b-98ba-8c7529e7884e}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{1f11e07b-ebd8-47ac-9888-f233a770e976}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="330">
                <terminals>
                    <terminal orientation="0" y="-6" id="4" x="0"/>
                    <terminal orientation="2" y="6" id="5" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{2625bd1a-0be5-4133-8d2e-342fc250d4ed}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{6c67ae6d-47ed-4db6-a5f6-af71e767179b}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{d34fb49c-4430-4580-bd86-0ac880bbe534}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="300">
                <terminals>
                    <terminal orientation="0" y="-6" id="6" x="0"/>
                    <terminal orientation="2" y="6" id="7" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{04fda3d6-cc1d-4efa-82ff-409c79a1ac9f}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{bb4c07f5-f810-4d8b-ae1d-0aade4879c3a}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{287c59cc-fc8f-44d8-a29d-a6418d94de31}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="150">
                <terminals>
                    <terminal orientation="0" y="-6" id="8" x="0"/>
                    <terminal orientation="2" y="6" id="9" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{b412fd5a-6dc2-4b98-af0b-37b62eddc0f3}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{ef3a8563-f692-415b-bb32-7782ffc04235}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{75dfe47e-5c80-46d7-b13c-556f58727967}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="360">
                <terminals>
                    <terminal orientation="0" y="-6" id="10" x="0"/>
                    <terminal orientation="2" y="6" id="11" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{ace79daa-58d0-4a33-97f4-46eebc1ca39e}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{20899fa5-6708-461a-8b1a-2f07ef394f94}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="250" uuid="{bbd630d6-b162-4588-88f9-7a0d9ce9de88}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="150">
                <terminals>
                    <terminal orientation="0" y="-6" id="12" x="0"/>
                    <terminal orientation="2" y="6" id="13" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{049b99a5-85c7-41d5-b7c1-57c15d117ed9}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="390">
                <terminals>
                    <terminal orientation="0" y="-6" id="14" x="0"/>
                    <terminal orientation="2" y="6" id="15" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{e4172e00-e509-4324-bdbc-6466deb799c0}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{ebec910c-9e0b-4367-b8a8-848f4c18485c}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{0731d9d7-270b-427d-8c13-49576a4b8d31}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="120">
                <terminals>
                    <terminal orientation="0" y="-6" id="16" x="0"/>
                    <terminal orientation="2" y="6" id="17" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{66622b39-3712-440a-bf1f-15f10d590196}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{0733d46c-4885-474c-91a9-f94fc9abc231}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{084fb9ba-7145-421c-b4bd-eb8300532562}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="210">
                <terminals>
                    <terminal orientation="0" y="-6" id="18" x="0"/>
                    <terminal orientation="2" y="6" id="19" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{8a0821e4-9bbd-40ff-b5d5-a5c74ea98bc3}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="240">
                <terminals>
                    <terminal orientation="0" y="-6" id="20" x="0"/>
                    <terminal orientation="2" y="6" id="21" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{f13ac1f4-c2c5-4acc-88a7-46dbcb29f354}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{229cade0-16ca-439d-a0d2-04c6e6e4511a}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="250" uuid="{962946c5-bdf0-4dfc-b5e2-0ae381662e0f}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="120">
                <terminals>
                    <terminal orientation="0" y="-6" id="22" x="0"/>
                    <terminal orientation="2" y="6" id="23" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{f6667c91-b0c7-4148-a7f2-0e5391b4680a}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="180">
                <terminals>
                    <terminal orientation="0" y="-6" id="24" x="0"/>
                    <terminal orientation="2" y="6" id="25" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_from="UserText" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-2" Valignment="AlignTop" frame="false" uuid="{a1b78193-c465-456e-8bc0-691b05601509}" text_width="-1" font="Sans Serif,7,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text>_</text>
                    <dynamic_elmt_text text_from="ElementInfo" keep_visual_rotation="true" rotation="0" Halignment="AlignLeft" y="-17.5" Valignment="AlignTop" frame="false" uuid="{e1eed19f-eb88-4e1e-8a01-d44621f40865}" text_width="-1" font="Sans Serif,10,-1,5,0,0,0,0,0,0,normal" x="5">
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{cb554491-36a5-497e-be6a-aa6680de2dc9}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="360">
                <terminals>
                    <terminal orientation="0" y="-6" id="26" x="0"/>
                    <terminal orientation="2" y="6" id="27" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{3a322586-29b4-4164-94aa-222ea357223b}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="390">
                <terminals>
                    <terminal orientation="0" y="-6" id="28" x="0"/>
                    <terminal orientation="2" y="6" id="29" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{e1e99706-0415-4ac3-a272-880bfa15e843}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="150">
                <terminals>
                    <terminal orientation="0" y="-6" id="30" x="0"/>
                    <terminal orientation="2" y="6" id="31" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{2d7e8b7a-f3c9-4bfc-8cd0-6934661ad3ca}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="270">
                <terminals>
                    <terminal orientation="0" y="-6" id="32" x="0"/>
                    <terminal orientation="2" y="6" id="33" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{a1086f68-1ba1-4545-bc0d-ad4810aac64e}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="330">
                <terminals>
                    <terminal orientation="0" y="-6" id="34" x="0"/>
                    <terminal orientation="2" y="6" id="35" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="90" uuid="{db3b0f6c-eb33-4145-936f-f49ed9ab3671}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="300">
                <terminals>
                    <terminal orientation="0" y="-6" id="36" x="0"/>
                    <terminal orientation="2" y="6" id="37" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="250" uuid="{5ff49050-7b3a-4358-ab2f-6facc984a22b}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="240">
                <terminals>
                    <terminal orientation="0" y="-6" id="38" x="0"/>
                    <terminal orientation="2" y="6" id="39" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{bd9e46e1-3983-4375-a784-e1050f20a698}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="180">
                <terminals>
                    <terminal orientation="0" y="-6" id="40" x="0"/>
                    <terminal orientation="2" y="6" id="41" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{5c5904b2-0e90-46e4-97b9-cf435c9025d8}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="120">
                <terminals>
                    <terminal orientation="0" y="-6" id="42" x="0"/>
                    <terminal orientation="2" y="6" id="43" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="170" uuid="{b5994a0a-e422-4751-b714-bf87ff66246c}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="240">
                <terminals>
                    <terminal orientation="0" y="-6" id="44" x="0"/>
                    <terminal orientation="2" y="6" id="45" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="250" uuid="{b010b840-124e-45a6-94a0-2d2f59f0a74c}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="210">
                <terminals>
                    <terminal orientation="0" y="-6" id="46" x="0"/>
                    <terminal orientation="2" y="6" id="47" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
            <element orientation="0" prefix="X" z="10" y="250" uuid="{8240ec6e-d542-4d27-838c-85bbf63b67b7}" type="embed://import/10_electric/10_allpole/130_terminals&amp;terminal_strips/borne_continuite.elmt" freezeLabel="false" x="180">
                <terminals>
                    <terminal orientation="0" y="-6" id="48" x="0"/>
                    <terminal orientation="2" y="6" id="49" x="0"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                        <text>_</text>
                        <text></text>
                </dynamic_texts>
                <texts_groups/>
            </element>
        </elements>
    </diagram>
    <diagram version="0.90-DEV+ccfb46b35c957a06d79751d3" rowsize="80" cols="15" folio="%id/%total" order="2" plant="" title="" locmach="" author="" displayrows="true" date="null" freezeNewElement="false" displayAt="bottom" colsize="72" displaycols="true" auto_page_num="Neue auto-nummerierte Folie anlegen" indexrev="" freezeNewConductor="false" height="660" rows="8" filename="" titleblocktemplate="für A3" titleblocktemplateCollection="embedded">
        <properties>
        </properties>
        <tables>
            <graphics_table name=" 1" y="70" width="1040" uuid="{05c34679-0623-4576-b264-9f78593fa779}" height="550" display_n_row="22" x="50">
                <graphics_header>
                    <margins>5;5;10;5</margins>
                </graphics_header>
                <model>
                    <project_data_base_model>
                        <identifier>nomenclature</identifier>
                        <query>SELECT diagram_position, label FROM element_nomenclature_view WHERE ( element_type = 'Terminale' OR element_type = 'Simple' OR element_sub_type = 'commutator' OR element_sub_type = 'coil' OR element_sub_type = 'protection') ORDER BY diagram_position, label</query>
                        <index00 alignment="AlignLeft" margins="5;5;10;5" font="Sans Serif,9,-1,5,50,0,0,0,0,0"/>
                        <header_data>
                            <data orientation="Horizontal" role="" section="0"></data>
                            <data orientation="Horizontal" role="TextAlignmentRole" section="0">AlignLeft</data>
                            <data orientation="Horizontal" role="FontRole" section="0">Sans Serif,9,-1,5,50,0,0,0,0,0</data>
                        </header_data>
                    </project_data_base_model>
                </model>
            </graphics_table>
        </tables>
    </diagram>
    <diagram version="0.90-DEV+ccfb46b35c957a06d79751d3" rowsize="80" cols="15" folio="%id/%total" order="3" plant="" title="" locmach="" author="" displayrows="true" date="null" freezeNewElement="false" displayAt="bottom" colsize="72" displaycols="true" auto_page_num="Neue auto-nummerierte Folie anlegen" indexrev="" freezeNewConductor="false" height="660" rows="8" filename="" titleblocktemplate="für A3" titleblocktemplateCollection="embedded">
        <properties>
        </properties>
        <tables>
            <graphics_table name=" 2" y="70" width="1040" uuid="{a399efef-e128-4cdb-be73-a08cf4dec3ef}" height="75" display_n_row="22" x="50">
                <graphics_header>
                </graphics_header>
                <previous_table uuid="{05c34679-0623-4576-b264-9f78593fa779}"/>
            </graphics_table>
        </tables>
    </diagram>
    <collection>
        <category name="import">
            <names>
                <name lang="it">Elementi importati</name>
                <name lang="el">Εισηγμένα στοιχεία</name>
                <name lang="es">Elementos importados</name>
                <name lang="pt">elementos importados</name>
                <name lang="ru">Импортированные элементы</name>
                <name lang="nl">Elementen geïmporteerd</name>
                <name lang="de">Importierte elemente</name>
                <name lang="pl">Elementy importowane</name>
                <name lang="da">Importerede elementer</name>
                <name lang="fr">Éléments importés</name>
                <name lang="ro">Elemente importate</name>
                <name lang="ca">Elements importats</name>
                <name lang="tr">İthal öğeler</name>
                <name lang="sl">Uvoženi elementi</name>
                <name lang="cs">Zavedené prvky</name>
                <name lang="hr">Uvezeni elementi</name>
                <name lang="en">Imported elements</name>
            </names>
            <category name="10_electric">
                <names>
                    <name lang="el">Ηλεκτρικά</name>
                    <name lang="it">Elettrica</name>
                    <name lang="es">Eléctrica</name>
                    <name lang="ru">Электротехника</name>
                    <name lang="nl">Elektrotechniek</name>
                    <name lang="de">Elektrik</name>
                    <name lang="pl">Elektrotechnika</name>
                    <name lang="da">Elektrisk</name>
                    <name lang="ja">電気</name>
                    <name lang="fr">Electrique</name>
                    <name lang="cs">Elektrotechnika</name>
                    <name lang="en">Electric</name>
                </names>
                <category name="10_allpole">
                    <names>
                        <name lang="it">Multifilare</name>
                        <name lang="el">Πολυγραμμικό</name>
                        <name lang="es">Multifilar</name>
                        <name lang="ru">Многополюсные</name>
                        <name lang="nl">Veel polig</name>
                        <name lang="de">Allpolig</name>
                        <name lang="pl">Schematy wieloliniowe</name>
                        <name lang="da">Flere ledere</name>
                        <name lang="ja">複線</name>
                        <name lang="fr">Multifilaire</name>
                        <name lang="hu">Többvonalas szimbólumok</name>
                        <name lang="cs">Vícežilový</name>
                        <name lang="en">All-pole</name>
                    </names>
                    <category name="130_terminals&amp;terminal_strips">
                        <names>
                            <name lang="it">Terminali</name>
                            <name lang="el">Ακροδέκτες και σειρές ακροδεκτών</name>
                            <name lang="pt">Terminais</name>
                            <name lang="es">Terminales</name>
                            <name lang="ru">Клеммы и клеммники</name>
                            <name lang="nl">Klemmenlijst</name>
                            <name lang="de">Klemmen und Klemmleisten</name>
                            <name lang="ar">طرفيات توصيل</name>
                            <name lang="pl">Złącza i zaciski</name>
                            <name lang="da">Klemmer og klemmerækker</name>
                            <name lang="ja">端子と端子台</name>
                            <name lang="fr">Bornes et borniers</name>
                            <name lang="hu">Sorkapcsok</name>
                            <name lang="cs">Svorky</name>
                            <name lang="en">Terminals and terminal strips</name>
                        </names>
                        <element name="borne_continuite.elmt">
                            <definition ic="true" link_type="terminal" hotspot_x="4" hotspot_y="15" version="0.4" width="10" height="30" type="element">
                                <uuid uuid="{2A9F30BF-E099-47DA-9D11-13983B8F7AA6}"/>
                                <names>
                                    <name lang="ar">طرف توصيل</name>
                                    <name lang="de">Klemme</name>
                                    <name lang="ru">Клеммное соединение</name>
                                    <name lang="pt">Terminal de combinação</name>
                                    <name lang="en">Terminal block</name>
                                    <name lang="it">Terminale di unione</name>
                                    <name lang="fr">Borne continuité</name>
                                    <name lang="pl">Zacisk</name>
                                    <name lang="es">Terminal de unión</name>
                                    <name lang="nl">klem doorgang</name>
                                    <name lang="cs">Spojovací svorka</name>
                                    <name lang="hu">Sorkapocs</name>
                                </names>
                                <description>
                                    <input y="8" size="7" text="_" tagg="none" x="5"/>
                                    <input y="-5" size="10" text="_" tagg="label" x="5"/>
                                    <line end1="none" end2="none" y2="3" length2="1.5" x1="0" x2="0" antialias="false" style="line-style:normal;line-weight:normal;filling:none;color:black" length1="1.5" y1="10"/>
                                    <line end1="none" end2="none" y2="-3" length2="1.5" x1="0" x2="0" antialias="false" style="line-style:normal;line-weight:normal;filling:none;color:black" length1="1.5" y1="-10"/>
                                    <circle diameter="5" y="-2.5" antialias="true" style="line-style:normal;line-weight:normal;filling:none;color:black" x="-2.5"/>
                                    <terminal orientation="n" y="-10" x="0"/>
                                    <terminal orientation="s" y="10" x="0"/>
                                </description>
                            </definition>
                        </element>
                    </category>
                </category>
            </category>
        </category>
    </collection>
</project>
Activities
black_sun
2022-03-31 19:07
developer   ~0000550
Fixed in commit 5a51f6bace3115bb597ba472eb8938566c9d0fcf
black_sun
2022-03-31 19:08
developer   ~0000551
plc-user
2022-03-31 23:33
reporter   ~0000552
Sad to say, but no change in behavior when following the "steps to reproduce".
Software crashes as before:
~$ qelectrotech
failed to load "qt_de" "/usr/share/qt5/translations" ( sources/qetapp.cpp 199 setLanguage )
failed to load "qt_de" "/usr/share/qelectrotech/lang/" ( sources/qetapp.cpp 203 setLanguage )
is QRegularExpression ok?
Export XML de 3 schemas
"exporting diagram \"\"" [ Diagram(0x560b0ba2df90) ]
"exporting diagram \"\"" [ Diagram(0x560b0b9c29a0) ]
"exporting diagram \"\"" [ Diagram(0x560b0b7e6c20) ]
23:26:17.722 Info: Start-up
23:26:17.975 Info: Elements collection reload
23:26:18.195 Info: Elements collection finished to be loaded in 0.219 seconds
23:26:18.414 Info: debugging enabled: false
23:26:18.414 Info: Qt library version: 5.15.2
23:26:18.414 Info: Qt library location default prefix: "/usr"
23:26:18.414 Info: Qt library location documentation: "/usr/share/qt5/doc"
23:26:18.415 Info: Qt library location headers: "/usr/include/x86_64-linux-gnu/qt5"
23:26:18.415 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
23:26:18.415 Info: Qt library location executables: "/usr/lib/x86_64-linux-gnu/qt5/libexec"
23:26:18.415 Info: Qt library location Qt binaries: "/usr/lib/qt5/bin"
23:26:18.415 Info: Qt library location Qt plugins: "/usr/lib/x86_64-linux-gnu/qt5/plugins"
23:26:18.415 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/imports"
23:26:18.415 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/qml"
23:26:18.415 Info: Qt library location dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt5"
23:26:18.415 Info: Qt library location independent Qt data: "/usr/share/qt5"
23:26:18.415 Info: Qt library location translation: "/usr/share/qt5/translations"
23:26:18.415 Info: Qt library location examples: "/usr/lib/x86_64-linux-gnu/qt5/examples"
23:26:18.415 Info: Qt library location Qt testcases: "/usr/tests"
23:26:18.415 Info: Qt library location Qt settings: "/etc/xdg"
23:26:18.415 Info: "QElectroTech V 0.90-DEV+5a51f6bacb0a58100c957a06d79751d3"
23:26:18.415 Info: "Compilation: GCC 11.2.0"
23:26:18.415 Info: "Built with Qt 5.15.2 - Date : Mar 31 2022 : 20:46:33"
23:26:18.415 Info: "Run with Qt 5.15.2 using 8 thread(s)"
23:26:18.416 Info: "CPU : model name\t: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz\n"
23:26:18.416 Info: "RAM Total : 31810 MB"
23:26:18.416 Info: "RAM Available : 29861 MB"
23:26:18.416 Info: "GPU : Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] (rev 01)\n"
23:26:18.416 Info: "GPU RAM : "
23:26:18.416 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.16.0-6-amd64"
23:26:18.416 Info: *** Qt screens ***
23:26:18.416 Info: "( 1 : 1920 x 1080 )"
Segmentation fault
black_sun
2022-04-01 20:08
developer   ~0000553
Fixed with this commit https://git.tuxfamily.org/qet/qet.git/commit/?id=ce21a812c03c56a57e4ca9b6b3e38aaad2361f4a
Issue History
2021-09-16 20:22 plc-user New Issue
2021-09-16 20:22 plc-user File Added: QET-Crash-Test.qet
2022-03-31 19:07 black_sun Note Added: 0000550
2022-03-31 19:08 black_sun Assigned To => black_sun
2022-03-31 19:08 black_sun Status new => resolved
2022-03-31 19:08 black_sun Resolution open => fixed
2022-03-31 19:08 black_sun Note Added: 0000551
2022-03-31 23:33 plc-user Status resolved => feedback
2022-03-31 23:33 plc-user Resolution fixed => reopened
2022-03-31 23:33 plc-user Note Added: 0000552
2022-04-01 20:08 black_sun Status feedback => resolved
2022-04-01 20:08 black_sun Note Added: 0000553
