0000178 | QElectroTech | website | public | 2019-11-23 12:31 | 2025-06-05 16:09 |
Reporter | andrzej@mazurkiewicz.org | Assigned To | |||
Summary | 0000178: Incorrect link on the english documentation page. | ||||
Description | https://download.qelectrotech.org/qet/manual_0.7/build/en/element/what_is.html The links from the above page to the sections: Simple Master Slave Reference folio following Previous reference folio Terminal block are incorrect. However links with these same titles from the page https://download.qelectrotech.org/qet/manual_0.7/build/en/element/index.html exist. Regards Andrzej Mazurkiewicz | ||||
Steps To Reproduce | Go to: https://download.qelectrotech.org/qet/manual_0.7/build/en/element/what_is.html Try it. You will get 404 error. Go to https://download.qelectrotech.org/qet/manual_0.7/build/en/element/index.html Try links again. You will get the necessary pages. | ||||
Tags | english, web documentation | ||||
Thanks Andrzej, maybe you could fix it : https://github.com/qelectrotech/qelectrotech-doc |
Documentation still / again can't be reached. Link from ˋHilfe Online-Dokumentation (englisch) → ˊ leads to https://download.tuxfamily.org/qet/manual_0.7/build/index.html for me, result is "Fehler: Netzwerk-Zeitüberschreitung" Further research has result: download.tuxfamily.org is down. |
"tuxfamily.org" problem has become resolved in DEV-Version. Click on ˋHilfe → Online-Dokumentatioˊ now opens https://download.qelectrotech.org/qet/manual_0.7/build/index.html what does exist. O tested for German, English, Spanish UI So this one an be closed with "fixed for Target V. 0.100"? For the sake of completeness my complete Version info: QElectroTech V 0.100.0-dev Compilation : GCC 13.3.0 Built with Qt 5.15.16 - x86_64 - Date : May 30 2025 : 10:22:25 Run with Qt 5.15.16 using 12 thread(s) CPU : NAME AMD RYZEN 5 3600 6-CORE PROCESSOR RAM Total : 16 GB RAM Available : 7 GB GPU : VideoProcessor GeForce GT 710 GPU RAM : RAM Total : AdapterRAM 2147483648 B OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045 *** Qt screens *** ( 1 : 1920 x 1080 ) |
2019-11-23 12:31 | andrzej@mazurkiewicz.org | New Issue | |
2019-11-23 12:31 | andrzej@mazurkiewicz.org | Tag Attached: english | |
2019-11-23 12:31 | andrzej@mazurkiewicz.org | Tag Attached: web documentation | |
2019-11-23 12:34 | scorpio810_mantis | Note Added: 0000385 | |
2021-02-15 00:44 |
Product Version | => 0.8 |
2021-02-15 00:45 |
2021-02-15 00:47 |
2025-06-04 08:40 | RainerBielefeld | Note Added: 0000807 | |
2025-06-05 16:09 | RainerBielefeld | Note Added: 0000808 |
