0000178QElectroTechwebsitepublic2025-06-07 11:55
Reporterandrzej@mazurkiewicz.org Assigned Toplc-user
Status closedResolutionfixed
Fixed in Version0.100
Summary0000178: Incorrect link on the english documentation page.
Descriptionhttps://download.qelectrotech.org/qet/manual_0.7/build/en/element/what_is.html
The links from the above page to the sections:
        Simple
        Master
        Slave
        Reference folio following
        Previous reference folio
        Terminal block
are incorrect.
However links with these same titles from the page
https://download.qelectrotech.org/qet/manual_0.7/build/en/element/index.html
exist.
Regards
Andrzej Mazurkiewicz
Steps To ReproduceGo to:
Try it.
You will get 404 error.
Go to
Try links again.
You will get the necessary pages.
Tagsenglish, web documentation
Activities
scorpio810_mantis
2019-11-23 12:34
administrator   ~0000385
Thanks Andrzej,
maybe you could fix it :
https://github.com/qelectrotech/qelectrotech-doc
RainerBielefeld
2025-06-04 08:40
reporter   ~0000807
Documentation still / again can't be reached.
Link from ˋHilfe Online-Dokumentation (englisch) → ˊ leads to
https://download.tuxfamily.org/qet/manual_0.7/build/index.html for me, result is
"Fehler: Netzwerk-Zeitüberschreitung"
Further research has result: download.tuxfamily.org is down.
RainerBielefeld
2025-06-05 16:09
reporter   ~0000808
"tuxfamily.org" problem has become resolved in DEV-Version.
Click on ˋHilfe → Online-Dokumentatioˊ now opens
  https://download.qelectrotech.org/qet/manual_0.7/build/index.html
what does exist.
O tested for German, English, Spanish UI
So this one an be closed with "fixed for Target V. 0.100"?
For the sake of completeness my complete Version info:
QElectroTech V 0.100.0-dev
Compilation : GCC 13.3.0
Built with Qt 5.15.16 - x86_64 - Date : May 30 2025 : 10:22:25
Run with Qt 5.15.16 using 12 thread(s)
CPU : NAME AMD RYZEN 5 3600 6-CORE PROCESSOR
RAM Total : 16 GB
RAM Available : 7 GB
GPU : VideoProcessor GeForce GT 710
GPU RAM : RAM Total : AdapterRAM 2147483648 B
OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045
*** Qt screens ***
( 1 : 1920 x 1080 )
Issue History
2019-11-23 12:31 andrzej@mazurkiewicz.org New Issue
2019-11-23 12:31 andrzej@mazurkiewicz.org Tag Attached: english
2019-11-23 12:31 andrzej@mazurkiewicz.org Tag Attached: web documentation
2019-11-23 12:34 scorpio810_mantis Note Added: 0000385
2021-02-15 00:44 user245 Product Version => 0.8
2021-02-15 00:47 user245 Product Version 0.8 => SVN/trunk
2025-06-04 08:40 RainerBielefeld Note Added: 0000807
2025-06-05 16:09 RainerBielefeld Note Added: 0000808
2025-06-07 11:55 plc-user Assigned To => plc-user
2025-06-07 11:55 plc-user Status new => closed
2025-06-07 11:55 plc-user Resolution open => fixed
2025-06-07 11:55 plc-user Fixed in Version => 0.100
