0000166 | QElectroTech | website | public | 2018-11-22 10:21 | 2021-02-15 00:53 |
Reporter | Kristian | Assigned To | black_sun_2012 | ||
Priority | normal | Severity | feature | Reproducibility | have not tried |
Platform | all | OS | all | OS Version | all |
Summary | 0000166: Make path to user defined templates configurable | ||||
Description | We are working in a team using the same library of a common user collection shared on a network drive. Configuring that folder in settings is very convenient as we are all up to date. The sme feature would be nice to have for the templates. Existing: Setting / General / Collection --> User collection path New: Setting / General / Templates --> User templates path Thanks in advance | ||||
Tags | menu | ||||
Attached Files | |||||
Thanks Kristian to report it. A possible patch, but only work on unix system like linux macOS. I think we need to add new QFileDialog widget in settings for chose user templates.
custom_tbt.diff (1,517 bytes)
diff --git a/sources/qetapp.cpp b/sources/qetapp.cpp index .. 100644 --- a/sources/qetapp.cpp +++ b/sources/qetapp.cpp @@ -491,7 +491,7 @@ } } else if (m_user_custom_elements_dir != "default") { - return m_user_custom_elements_dir; + return m_user_custom_elements_dir + "/elements/"; } return(configDir() + "elements/"); @@ -559,6 +559,27 @@ templates collection. */ QString QETApp::customTitleBlockTemplatesDir() { + if (m_user_custom_elements_dir.isEmpty()) + { + QSettings settings; + QString path = settings.value("elements-collections/custom-collection-path", "default").toString(); + if (path != "default" && !path.isEmpty()) + { + QDir dir(path); + if (dir.exists()) + { + m_user_custom_elements_dir = path; + return m_user_custom_elements_dir; + } + } + else { + m_user_custom_elements_dir = "default"; + } + } + else if (m_user_custom_elements_dir != "default") { + return (m_user_custom_elements_dir + "/titleblocks/"); + } + return(configDir() + "titleblocks/"); } diff --git a/sources/ui/configpage/generalconfigurationpage.ui b/sources/ui/configpage/generalconfigurationpage.ui index .. 100644 --- a/sources/ui/configpage/generalconfigurationpage.ui +++ b/sources/ui/configpage/generalconfigurationpage.ui @@ -41,7 +41,7 @@ </size> </property> <property name="currentIndex"> - <number>0</number> + <number>2</number> </property> <widget class="QWidget" name="tab_3"> <attribute name="title"> |
Fixed by 5605 commit |
2018-11-22 10:21 | Kristian | New Issue | |
2018-11-22 10:21 | Kristian | Tag Attached: menu | |
2018-11-25 10:00 | scorpio810_mantis | File Added: custom_tbt.diff | |
2018-11-25 10:00 | scorpio810_mantis | Note Added: 0000357 | |
2018-11-25 10:01 | scorpio810_mantis | Assigned To | => black_sun_2012 |
2018-11-25 10:01 | scorpio810_mantis | Status | new => assigned |
2018-11-25 10:03 | scorpio810_mantis | Note Edited: 0000357 | |
2018-11-25 10:57 | scorpio810_mantis | Note Added: 0000358 | |
2018-11-25 10:57 | scorpio810_mantis | Note Edited: 0000358 | |
2018-11-25 12:03 | scorpio810_mantis | Status | assigned => resolved |
2018-11-25 12:03 | scorpio810_mantis | Resolution | open => fixed |
2018-11-25 12:03 | scorpio810_mantis | Fixed in Version | => SVN/trunk |
2021-02-15 00:47 |
Product Version | SVN/branches/0.x => SVN/trunk |
2021-02-15 00:53 |
Category | other => website |
