| 0000140 | QElectroTech | website | public | 2017-06-14 14:14 | 2021-02-15 00:53 |
| Reporter | remi | Assigned To | |||
| Priority | normal | Severity | block | Reproducibility | have not tried |
| Platform | XDG compliant | ||||
| Summary | 0000140: [RFE] Comply with XDG configuration | ||||
| Description | Instead of using ~/.qet, use insteand XDG standard directories => https://specifications.freedesktop.org/basedir-spec/basedir-spec-latest.html elements => $XDG_DATA_HOME ($HOME/.local/share) titleblocks => idem elements_cache.sqlite => $XDG_CACHE_HOME ($HOME/.cache) qelectrotech.conf => $XDG_CONFIG_HOME ($HOME/.config) | ||||
We use the native format for QSettings : http://doc.qt.io/qt-5/qsettings.html#details the configuration files are stored in : For GNU/Linux distributions: $HOME/.config/QElectroTech/QElectroTech.conf For Mac OS X: $HOME/Library/Preferences/QElectroTech/QElectroTech.plist For Windows, in the registry: HKEY_CURRENT_USER\Software\QElectroTech\ |
| 2017-06-14 14:14 | remi | New Issue | |
| 2017-07-13 17:04 | scorpio810_mantis | Note Added: 0000244 | |
| 2021-02-15 00:45 |
| 2021-02-15 00:49 |
Severity | minor => block |
| 2021-02-15 00:53 |
Category | other => website |
