| 0000133 | QElectroTech | website | public | 2017-01-10 12:20 | 2026-09-29 05:18 |
| Priority | normal | Severity | block | Reproducibility | always |
| Platform | Qt5.6.2, kf5.29.0, Plasma5.8.5, | OS | 64bit, Linux4.9.1, gcc5.4.0, | OS Version | Xorg 1.19.0, Mageia6 (dev) |
| Summary | 0000133: The location field shown at element sometimes do not show last line | ||||
| Description | r4836, but i have seen this earlier too. Workaround: user enters a bunch of spaces after last word -> line shows up | ||||
| Attached Files | |||||
This no longer happens on current master (2801d93af). Element texts have been redrawn by new code since 0.7, and the wrapped text now keeps every line. Tested with your text "Kan leverera 7A kont på 230V" as the comment of an element in affuteuse_250h.qet, with the text box width set to 20, 35, 50, 80 and 120, and with longer texts wrapping up to 15 lines. Every word appeared in all 20 exports. At width 50 your text wraps to four lines, and "230V" sits inside the frame. Closing as fixed. Please reopen if you still see it on a current version. |
| 2017-01-10 12:20 | Morganol | New Issue | |
| 2017-01-10 12:20 | Morganol | File Added: Screenshot_Location-sometimes last line is not visible.png | |
| 2021-02-15 00:45 |
| 2021-02-15 00:49 |
Severity | minor => block |
| 2021-02-15 00:50 |
| 2026-09-29 05:18 | ispyisail | Note Added: 0000913 | |
| 2026-09-29 05:18 | ispyisail | Status | new => resolved |
| 2026-09-29 05:18 | ispyisail | Resolution | open => fixed |
