0000123 | QElectroTech | website | public | 2016-12-12 17:34 | 2021-02-15 00:52 |
Reporter | Morganol | Assigned To | black_sun | ||
Priority | normal | Severity | crash | Reproducibility | have not tried |
Status | closed | Resolution | fixed | ||
Platform | Qt5.6.2, kf5.27.0, Plasma5.8.4, | OS | 64bit, Linux4.8.14, gcc5.4.0, | OS Version | Mageia 6 (devel) |
Summary | 0000123: Crash when linking slave element to master | ||||
Description | r4805 I was linking slaves to masters. Realised i had wrong element for a slave, so I deleted it, copied correct element to new position and linked it, crash. Attaching screenshot of qtdesigner from which i had launced QET in debug. | ||||
Steps To Reproduce | Have not seen this before, will report if i see it again. | ||||
Attached Files | |||||
Thought: It may be related that I some minutes before i was linking elements, saw that there were drawing artifacts around a diagonal dotted simple straight line when zooming the area that contained the line often got black. I deleted that line, redraw it, and saved and all seemed well (it did not crash when saving, like the well known bug) Then i continued working and after a while i got a crash as in Description. |
2016-12-12 17:34 | Morganol | New Issue | |
2016-12-12 17:34 | Morganol | File Added: Segfault when linking slave to master.png | |
2016-12-12 21:47 | Morganol | Note Added: 0000213 | |
2016-12-12 23:22 | scorpio810 | Assigned To | => black_sun |
2016-12-12 23:22 | scorpio810 | Status | new => assigned |
2018-03-29 15:41 | black_sun | Status | assigned => closed |
2018-03-29 15:41 | black_sun | Resolution | open => fixed |
2021-02-15 00:52 |
