| 0000113 | QElectroTech | website | public | 2016-10-28 11:55 | 2021-02-15 00:48 |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.2, | OS | 64 bit, Linux 4.8.4, gcc 5.4.0, | OS Version | Mageia 6 (devel) |
| Summary | 0000113: Clicking a wide element makes panels go wide | ||||
| Description | r4762 | ||||
| Steps To Reproduce | See attached video:
| Attached Files | |||||
Ah... Specifically it is the "Selection properties" panel that pops wide when the element is chosen, because of the preview of the element, and it does not scale within the panel space, instead extend the panel widt. Workaround: have that panel closed. Real fix would be to scale the preview to available height and width in "Selection properties" "Gneral" tab. |
Someone able to, can set the severity to low. I first guessed there was something going possibly dangerously wrong like pointer overflow, but it is just a missing scaling/cropping thing in that Selection properties dialogs preview functionality. |
It seem to be fixed by blacksun with r4781 "Minor fix : set a correct size of the pixmap displayed in the element properties widget" and i do not see the problem now. Thank you. Please close as FIXED |
| 2016-10-28 11:55 | Morganol | New Issue | |
| 2016-10-28 11:55 | Morganol | File Added: qet001-2016-10-28_11.46.57.mkv | |
| 2016-10-28 12:10 | Morganol | Note Added: 0000195 | |
| 2016-10-29 15:21 | Morganol | Note Added: 0000196 | |
| 2016-11-16 11:27 | Morganol | Note Added: 0000202 | |
| 2016-11-17 11:02 | scorpio810_mantis | Status | new => resolved |
| 2016-11-17 11:02 | scorpio810_mantis | Resolution | open => fixed |
| 2016-11-17 11:02 | scorpio810_mantis | Fixed in Version | => SVN/trunk |
| 2021-02-15 00:48 |
