0000111QElectroTechwebsitepublic2021-02-15 00:48
ReporterMorganol Assigned To
PrioritynormalSeverityfeatureReproducibilityalways
PlatformQt5.6.1, kf5.27.0, Plasma5.8.2, OS64 bit, Linux 4.8.4, gcc 5.4.0, OS VersionMageia 6 (devel)
Summary0000111: Variables logging actual file saving would be nice
DescriptionFor use in title blocks
Yes i know there is the File field on folios, but easy to forget to update, especially when saving often under new names...
Suggestion:
Variable name - Example:
%savedfilename - SuperThing.qet
%savedpathname - /home/peter/project/Super/QET/ (on Linux )
%savedtime - 14:35 (system format, preferrably excluding seconds)
%saveddate - 2016-09-27 (system format)
For obvious reasons the variables should be updated after file save dialog is confirmed, before file is saved.
Date and time should NOT get updated by opening the file, print/export, close.
TagsNo tags attached.
Activities
Morganol
2017-01-10 15:45
reporter   ~0000229
Example for the file SuperThing.qet, saved in /home/peter/project/Super/QET/, with time stamp 2016-09-27 14:35
When that .qet file is opened, set the following variables for that project:
Also, when file is saved: update all variables
Variables should be available for use in templates -> automatic and clear documentation on pdf and paper exports. - very nice for ever evolving projects which seem to be what i am always involved in... ; my fellow electrician need to see he have correct revision of the print.
(it easy to forget to manually update revision and date fields correctly)
scorpio810_mantis
2018-08-06 17:35
administrator   ~0000355
See : https://qelectrotech.org/forum/viewtopic.php?pid=8442#p8442
Issue History
2016-10-28 03:08 Morganol New Issue
2017-01-10 15:45 Morganol Note Added: 0000229
2018-08-06 17:35 scorpio810_mantis Note Added: 0000355
2018-08-06 18:25 scorpio810_mantis Status new => resolved
2018-08-06 18:25 scorpio810_mantis Resolution open => fixed
2018-08-06 18:25 scorpio810_mantis Fixed in Version => SVN/trunk
2021-02-15 00:48 user245 Category Diagram Editor => website
