| 0000105 | QElectroTech | website | public | 2016-10-18 12:35 | 2026-10-01 02:29 |
| Priority | normal | Severity | block | Reproducibility | always |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.1, | OS | Linux 4.8.2, gcc 5.4.0, | OS Version | Mageia 6 (devel) |
| Summary | 0000105: Conductors at angle instead of orthogonal - with steps to reproduce | ||||
| Description | r4748 | ||||
| Steps To Reproduce | 1) load minim2b.qet (attached zipped) 2) move center valve upwards => See the conductor at pump going up slanting like "/", see attached image 3) save under new name, close file 4) open file => conductor is now angled but ofset and seem to be unconnected, see attached image 5) move the elements and conductor redraws correctly | ||||
| Attached Files | |||||
Also see video at https://qelectrotech.org/forum/viewtopic.php?pid=5734#p5734 |
Fixed by GitHub #1127, merged on 2026-09-28: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/1127 The fix will be in the next release. If you still see the problem in a build that includes it, add a note here and we will reopen this. |
| 2016-10-18 12:35 | Morganol | New Issue | |
| 2016-10-18 12:35 | Morganol | File Added: minim2b.zip | |
| 2016-10-18 12:35 | Morganol | File Added: minim2b_center-valve-moved-upwards_makes-angled-connector.png | |
| 2016-10-18 12:36 | Morganol | File Added: minim2b_loose-connector-after-save-reopen.png | |
| 2016-10-20 00:29 | Morganol | Note Added: 0000186 | |
| 2021-02-15 00:45 |
| 2021-02-15 00:49 |
Severity | minor => block |
| 2021-02-15 00:50 |
| 2026-10-01 02:29 | ispyisail | Note Added: 0000917 | |
| 2026-10-01 02:29 | ispyisail | Status | new => resolved |
| 2026-10-01 02:29 | ispyisail | Resolution | open => fixed |
